Warning message
Exporting a certificate from one ASA pair to another
Jun 3rd, 2009
Does anyone know if it possible to export a security certificate from one set of ASA's to another? And how this might be done?
From the documentation I haven't seen anything about this. From experience you need a CSR to which you then add the certificate which is validated against a trustpoint. If there is no CSR on the 2nd set of ASA's then no cert can be imported?
watsoncisco Wed, 06/03/2009 - 00:50
Found the following in "Cisco Security Appliance Command Line Configuration Guide, Version 8.0" on Cisco Documentation:
"You can export and import the keypair and issued certificates associated with a trustpoint in PKCS12 format. This is useful if you wish to manually duplicate a trustpoint configuration on a different security appliance."
There are also sections describing how to do it.
