LACP Ethert-Channel and HP Network TEAM
Jun 3rd, 2009
I have a HP Server that I want to setup to use an etherchannel for 2Gbs bandwidth. I keep having the same problem, one of the NIC's will only negotiate 100mbs/full and the other will negotiate the full 1000mbs/full. I have had this issue on 2 HP servers now and I cant seem to figure out the problem. I have followed this guide with no success. Also if I try to statically set the speed/duplex it acts like the network cable is disconnected.
javascript:newWin('http://www.cisco.com/en/US/tech/tk389/tk213/technologies_configuration_example09186a008089a821.shtml')
Here is my configuration and some show information....
rmprodsw01#sh run int g2/27
Building configuration...
Current configuration : 203 bytes
interface GigabitEthernet2/27
description RMSTAGEBACKUP01-A-Po2
switchport
switchport access vlan 51
switchport mode access
no ip address
spanning-tree portfast
channel-group 2 mode active
end
rmprodsw01#sh run int g2/39
interface GigabitEthernet2/39
description RMSTAGEBACKUP01-B-Po2
switchport
no ip address
end
rmprodsw01#sh run int po2
Current configuration : 101 bytes
interface Port-channel2
description PORT_CHANNEL_TO_STAGEBACKUP01
switchport
no ip address
end
rmprodsw01#sh int status | inc STAGEBACK
Gi2/27 RMSTAGEBACKUP01-A- connected 51 a-full a-100 10/100/1000BaseT
Gi2/39 RMSTAGEBACKUP01-B- connected 51 a-full a-1000 10/100/1000BaseT
rmprodsw01#sh ether summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
Number of channel-groups in use: 4
Number of aggregators: 5
Group Port-channel Protocol Ports
2 Po2(SD) LACP Gi2/27(I)
2 Po2A(SU) LACP Gi2/39(P)
Collin Clark Wed, 06/03/2009 - 05:56
  • Purple, 4500 points or more
HP/Broadcom NICs and Cisco switches don't negotiate well. Hard set the switch ports and the NIC's to 100/full.
Hope that helps.
glen.grant Wed, 06/03/2009 - 14:02
I would check your cable . Gigabit speed needs all 8 wires to be in good in order to run gigabit so if its negotiating 100 meg then maybe 1 or more wires are faulty in your cable path .
thefindjack Thu, 06/04/2009 - 07:15
Thanks for all your replies, I did try to hard set the speed/duplex but that only resulted in the network card thinking the cable was disconnected. I replaced all the network cables and tried "channel-group 2 mode on", all with no resolution. I upgraded all the firmware on the card and all drivers, and still nothing. At this point Im thinking this is a hardware problem (even though it seems weird the card would just stop working at 1000Mbs). I tried the same configuration on another HP server and it worked just fine, and I know this working on this particular server in the past.
