Conect two routers over console port
Jun 3rd, 2009
Hi Guys ,
How conect two routers or firewall over console port for manager ?
Jorge
James Hawkins Sat, 06/06/2009 - 03:48
Hi Jorge,
I do not believe that you can connect to devices over console ports.
I have in the past connected from an aux port on a router to a console port on a switch using one of the old RJ45-RJ45 rollover cables Cisco used to ship with DB9-RJ45 adapters before they starting shipping DB9-RJ45 console cables.
You should be able to use the configuration in the document at the link below as a starting point.
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a008014f8e7.shtml
This document is for a terminal server with 16 async ports. The config below should be ok for an aux port.
ip host switch 2001 172.21.1.1
interface Loopback1
ip address 172.21.1.1 255.0.0.0
line aux 0
session-timeout 20
no exec
exec-timeout 0 0
Please rate if helpful.
group4entr200 Sun, 06/07/2009 - 15:01
Hello, we are a group of purdue students that are doing a success case analysis over cisco as a company. We would really appreciate it if you take a few mintues to answer a couple of questions.
-Are you satisfied with the services provided with this company?
-What do you like/dislike the most about cisco?
