Power for the Cisco 7975 phone...
Jun 3rd, 2009
I noticed that Inline Power isn't supported for this type of model and I was wondering if a CAT 3550 was able to provide enough power to make it work.
This is what I basically did for the config part on the switch.
Switch(config-if)#power inline auto
The Phone stays on a reset loop all the time.
Any ideas?
Chris Deren Wed, 06/03/2009 - 10:01
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Try "power inline delay shutdown 20 initial 300" port command.
HTH,
Chris
julienf28 Wed, 06/03/2009 - 10:08
That works thanks...what exactly is going on during the delay?
Chris Deren Wed, 06/03/2009 - 10:47
  • Hall of Fame,
Not sure exactly how it operates differently for these phones and why it's needed, but it works :-)
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.2_25_sec/command/reference/cli1.html#wp2170129
HTH, please rate all uselful posts!
Chris
