Duplex mismatch problem
Jun 3rd, 2009
I have this interesting duplex mismatch problem and hope that someone can help me. I started to see these errros ever since I moved these hosts from CAt OS (4006) to Cat IOS (6500)
For example this error below says fa1/23 is NOT FULL DUPLEX but if you see the config below the port fas1/23 is hard coded to 100/full.
10:25:08.790: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet1/23 (not full duplex), with PCFE40PA FastEthernet0/1 (full duplex)
interface FastEthernet1/23
switchport
switchport access vlan 912
switchport mode access
no ip address
speed 100
duplex full
But here is the interesting part, when I do show int fas1/23, it says that is set to half-duplex and that's where I'm lost
FastEthernet1/23 is up, line protocol is up (connected)
Hardware is C6k 100Mb 802.3, address is 0005.5f28.c6ee (bia 0005.5f28.c6ee)
Description: xxxxxx
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Half-duplex, 100Mb/s
I'm on Cisco 6506 with WS-SUP32P-GE runing 122-18.ZY2.bin. Line card in question is WS-X6348-RJ-45.
Collin Clark Wed, 06/03/2009 - 07:54
  • Purple, 4500 points or more
The server (or whatever device) is probably set to auto-negotiate and is setting the NIC to 100/half. This is very common on HP/Broadcom. Hard set the server(s) and you should b good to go.
Hope that helps.
nawas Wed, 06/03/2009 - 09:13
Other side is a Cisco 2621XM which is also set to 100/full. There is no command to change the port duplex to auto, isn't strange? Please see below
exe-6506-24(config)#int fa1/23
Cisco-6506(config-if)#du
Cisco-6506(config-if)#duplex ?
full Force full duplex operation
half Force half-duplex operation
exe-6506-24(config-if)#duplex
Collin Clark Wed, 06/03/2009 - 09:21
I *think* if you set the speed to auto, it automagically set the duplex to auto.
