lms 3.0/rme software upload issues
Jun 3rd, 2009
When I create a swim job in rme to any cisco ios device. the job fails with the same error no matter what device type or ios version is being used here it the error. " Device is locked for exclusive access.
The supported protocols for image transfer are: TFTP,SCP
Sufficient free space is available on disk2 for the new image.
SWIM1001: The input parameters to the Image Distribution/Image Import/Image Activate are invalid.
You may have used incorrect Device Data for this task.
Check the application log file for more details."
Joe Clarke Wed, 06/03/2009 - 08:55
The swim_debug.log in the SWIM job directory will have more details. This just points to some generic error.
