IPSEC Configuration
Answered Question
apcbpcbpcl Mon, 09/30/2013 - 09:24
we have two Router in DC setup. In router-1, SP1 link is terminated & in Router2, SP2 link is terminated.in both the router, with MPLS cloud, BGP is configured.
In Router1 VLAN2 IP: 172.26.0.253.
In Router2 VLAN2 IP: 172.26.4.253.
DC subnet: 172.24.0.0/24
Branch End LAN Segment: 172.27.1.128/27
Now from branch, we trying to implement IPSEC tunnel for DC Segment. SP1 & SP2 is configured as Active-standby.
In DC both Router config:
crypto isakmp policy 10
hash md5
encr 3des
authentication pre-share
crypto isakmp key <> address 0.0.0.0 0.0.0.0 no-xauth
crypto isakmp keepalive 30 5
crypto ipsec transform-set APDRPSET esp-3des esp-sha-hmac
crypto dynamic-map APDRPMAP 6
set transform-set APDRPSET
crypto map APDRPMAIN 6 ipsec-isakmp dynamic APDRPMAP
int vlan 2
IN Branch Router Config:
hash md5
encr 3des
crypto isakmp key <>address 172.26.0.253 no-xauth
crypto isakmp key <> address 172.26.4.253 no-xauth
mode tunnel
no crypto map APDRPMAP 6 ipsec-isakmp
set peer 172.26.0.253
match address 130
crypto map APDRPMAP 12 ipsec-isakmp
set peer 172.26.4.253
match address 130
access-list 130 permit ip 172.27.1.128 0.0.0.31 172.24.0.0 0.0.255.255
access-list 130 permit ip 172.17.220.32 0.0.0.3 172.24.0.0 0.0.255.255
aaccess-list 130 deny ip 172.27.1.128 0.0.0.31 any
access-list 130 deny ip 172.17.220.32 0.0.0.3 any
int gi 0/0
crypto map APDRPMAP
int gi 0/1 --> Secondary MPLS link.
crypto map APDRPMAP
Problem:
When, in branch end, both the link is up, it is creating tunnel with DC Primary Router IP: 172.26.0.253 & working perfectly fine.
When in branch end, primary link is going down, traffic towards sourcing DC is going via gi0/1. in Crypto, it is trying to peering with Primary DC Router IP only instead of Secondary DC-Router IP & resulting which, tunnel is not able to form.the state is MM_No State.
When, primary link is coming up, it is peering with 172.26.0.253 again & working fine.
we have tried to clear to crypto sessions in both the cases but didnt get expected result.
Pls let us know, where exactly we are doing wrong.
