Vlan's & Trunking
Jun 3rd, 2009
OK here goes
in my lab i have setup an 1801 with 3 vlans which work really well
now heres for the problem,
i have been trying to add another switch to the 1801, i have set 1 port on 1801 to be a trunk and also set 1 port on the other switch (ws-c3524) to trunk with it, the trunk comes up fine and vtp revisions are passed correctly, but when it comes to pinging i can't get any across the link
Giuseppe Larosa Wed, 06/03/2009 - 08:48
  • Hall of Fame,
    Founding Member
Hello Billy,
I would suggest you to post the relevant parts of configuration on both devices.
Two vlans can get trapped by a native vlan mismatch but the third one should work.
Have you enabled ip routing on the switch ?
Hope to help
Giuseppe
rshum Wed, 06/03/2009 - 08:52
When you are pinging are the source and destination machines on the same VLAN but on different switches? If they are on different VLAN's you need a layer 3 device to pass the packets.
billybong Wed, 06/03/2009 - 09:48
Thanks for the fast reply everyone, in answer to your questions the vlans are on seperate switch`s but on the same vlan`s, i have enabled IP routing on the 1801
as to configs what do you want as in sh ru, sh vlan, anything else?
many thanks
Giuseppe Larosa Wed, 06/03/2009 - 10:51
  • Hall of Fame,
    Founding Member
Hello Billy,
from sh run it is fine
also it is important to specify how you test your setup:
do you put a PC on vlan X on the switch on a port configured to be access port in vlan X and you try to ping default gateway for vlan X on C1801 ?
Hope to help
Giuseppe
billybong Thu, 06/04/2009 - 07:57
This is sh ru from the 1801, i have x.x.x.x out the ip`s
Building configuration...
Current configuration : 6823 bytes
! Last configuration change at 18:41:54 gmt Wed Jun 3 2009 by darren
! NVRAM config last updated at 23:00:14 gmt Wed Jun 3 2009
version 12.4
no service pad
service tcp-keepalives-in
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
enable secret
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
resource policy
clock timezone gmt 0
clock summer-time gmt recurring
no ip source-route
ip cef
no ip bootp server
ip ips sdf location flash://128MB.sdf autosave
ip ips notify SDEE
no ip ips notify log
ip ips name sdm_ips_rule
interface Loopback0
ip address 10.10.10.1 255.0.0.0
ip virtual-reassembly
interface FastEthernet0
no ip address
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet1
description!
interface FastEthernet2
description
interface FastEthernet3
interface FastEthernet4
switchport access vlan 2
interface FastEthernet5
interface FastEthernet6
switchport mode trunk
interface FastEthernet7
switchport access vlan 3
interface FastEthernet8
description
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface Vlan1
ip address X.X.X.X X.X.X.X
ip access-group 100 in
ip flow ingress
ip flow egress
interface Vlan2
ip nat inside
ip ips sdm_ips_rule in
interface Vlan3
ip nat outside
interface Vlan9
no ip address
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat inside source list 1 interface Vlan3 overload
control-plane
banner motd
billybong Thu, 06/04/2009 - 07:59
This is sh ru from the 3524, agian i have X.X.X.X IP`s
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname TestBed
username darren privilege 15 password 0 james
ip subnet-zero
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface VLAN1
no ip directed-broadcast
no ip route-cache
ip default-gateway X.X.X.X
line con 0
transport input none
stopbits 1
line vty 0 4
privilege level 15
login local
transport input telnet
line vty 5 15
login
end
lamav Thu, 06/04/2009 - 09:42
  • Blue, 1500 points or more
Hi, what are you trying to achieve and how are you trying to achieve it?
As Giuseppe pointed out, you should tell us what your test set up is in detail.
Whats with the NAT statements?
Can you also post the output of a "sh int trunk" on both switches?
billybong Thu, 06/04/2009 - 13:09
the "sh int trunk" only works on the 1801
1801
end
1802#sh int trunk
Port Mode Encapsulation Status Native vlan
Fa6 on 802.1q trunking 1
Port Vlans allowed on trunk
Fa6 1-1005
Port Vlans allowed and active in management domain
Fa6 1-3,9
Port Vlans in spanning tree forwarding state and not pruned
Fa6 1
The 3524-xl i have managed to get this
SW 2#sh run int f0/1
end
i have made a drawing of my network and added a few comments on what i'm trying to do
http://s655.photobucket.com/albums/uu271/billybong08/?action=view&current=Netwoklayout.jpg
Giuseppe Larosa Thu, 06/04/2009 - 22:32
  • Hall of Fame,
    Founding Member
Hello Billy,
almost all ports of 3524 are in vlan1 the default.
The only port in vlan2 is f0/24
To verify the trunk on c3524 use
sh int f0/1 switchport
verify also the list of vlans with
sh vlan
My guess is that you have connected a pc to a switch port you have assigned an ip address to it and you have tried to verify ip connectivity.
But if you use an ip address out of context (an ip subnet associated to a different vlan) the pc cannot reach any device.
Hope to help
Giuseppe
billybong Thu, 06/04/2009 - 23:38
Hi giuseppe
heres the sh int f0/1 switchport
TestBed#sh int f0/1 switchport
Switchport: Enabled
Administrative mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: Disabled
Access Mode VLAN: 0 ((Inactive))
Trunking Native Mode VLAN: 1 (default)
Trunking VLANs Enabled: ALL
Trunking VLANs Active: 1-3,9
Pruning VLANs Enabled: 2-1001
Priority for untagged frames: 0
Override vlan tag priority: FALSE
Voice VLAN: none
Appliance trust: none
Self Loopback: No
PauloHirakawa Fri, 06/05/2009 - 04:40
Hi billybong,
Why the interface FastEthernet6 is configured as a trunk and access mode on 1801?
billybong Fri, 06/05/2009 - 07:56
i think i left that statment in by accident i have removed it now, i was just trying something
