Outside Interface
Answered Question
Jun 3rd, 2009
what are the commands to configure an interface as the outside interface on a router and leave all others as inside
Correct Answer by srue about 7 years 7 months ago
ip inspect INSPECTNAME in
the easiest way to use that command is to set up your inspection rules and then apply that command on the inside interface.
http://www.cisco.com/en/US/docs/ios/sec_data_plane/configuration/guide/sec_cfg_content_ac_ps6350_TSD_Products_Configuration_Guide_Chapter.html
Overall Rating: 5 (1 ratings)
srue Wed, 06/03/2009 - 08:52
can you be more specific? NAT? IOS Firewall? etc?
Or do you mean in general?
