06-03-2009 09:34 AM - edited 03-14-2019 04:10 AM
I have UCCX 5.0.1
When a caller calls and the call is in the Queue , the caller doesn't hear the MOH
All the CTI Ports associated to the UCCX box have the user and network MOH set to the default MOH. The script has the hold and un hold steps. and still no music
do you know what do i need to do to get the music going?
thanks
Solved! Go to Solution.
06-03-2009 10:55 AM
There is a bug (don't have it) that states MMOH does not work or is not supported with UCCX, so I always use unicast MOH for this purpose.
Build a new MRGL/MRG without Multicast checked and apply it to the device pool used by the cti ports and see if it works then.
Chris
06-03-2009 09:55 AM
Make sure the device pool assigned to the cti ports has proper MRGL--> MRG --> MOH Server configured.
HTH,
Chris
06-03-2009 10:33 AM
The Device Pool associated to the CTI Ports has an MRGL where the MRG has the MOH servers selected
06-03-2009 10:43 AM
What codec are you using between the region applied to the cti ports and the MOH server?
Have you tried resetting the MOH server? Is it showing registered? Does it work for regular calls?
Chris
06-03-2009 10:50 AM
we are using G.711
I reset the MOH servers and that didn't work. what I notice though is that Multicast is configured and port based, and the hop count of the default music is 2
it works for the phones, it also works for other CSQs.
the MOHs are registered
06-03-2009 10:55 AM
Chris
