Cisco Secure Desktop and Tunnel Group Profiles
Jun 3rd, 2009
Okay Guys, I have a question. I am configuring remote vpn on an ASA 5540. Here is what I want to do but I am not sure if this is possible.
I want to set it up to where when a user goes to https://vpn.website.com they are prompted to select a GROUP and then logon. (Corporate users or Contract users) I have this part working. The problem comes in when I enable Cisco Secure Desktop. I only want my "Contract Users" to load CSD. The problem is when going to https://sslvpn.website.com it immediately starts to load CSD forcing all users to use CSD. My problem is I DO NOT want my corporate users being forced into CSD so I was hoping that you could FIRST select the profile and then CSD would load only if you are a "Contract User". I am aware of "without-csd" command for the Corporate Tunnel-group "" webvpn attributes, but it still loads CSD before allowing you to select a profile. Hope my scenario is making sense.
Here is my config:
CCCASA-5540# sho run webvpn
webvpn
enable outside
csd image disk0:/securedesktop_asa_3_3_0_129.pkg.zip
csd enable
svc image disk0:/anyconnect-win-2.2.0133-k9.pkg 1
svc enable
tunnel-group-list enable
CCCASA-5540# sho run tunn
CCCASA-5540# sho run tunnel-group
tunnel-group Corporate type remote-access
tunnel-group Corporate general-attributes
address-pool SSL_VPN_Pool
authentication-server-group SSL_VPN
default-group-policy Corporate
tunnel-group Corporate webvpn-attributes
group-alias Corporate enable
group-url https://0.0.0.0
/Corporate enable
without-csd
tunnel-group Consultant type remote-access
tunnel-group Consultant general-attributes
default-group-policy Consultant
tunnel-group Consultant webvpn-attributes
group-alias Consultant enable
group-url https://0.0.0.0/Consultant enable
CCCASA-5540# sho run group-po
group-policy Corporate internal
group-policy Corporate attributes
dns-server value 10.x.x.x
vpn-tunnel-protocol svc
group-policy Consultant internal
group-policy Consultant attributes
Anonymous (not verified) Tue, 06/09/2009 - 07:48
You can set up different login windows for different groups by using a combination of customization profiles and tunnel groups. For example, assuming that you had created a customization profile called salesgui, you can create a WebVPN tunnel group called sales that uses that customization profile, as the following URL:
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/vpngrp.html#wp1117540
