06-03-2009 10:12 AM
I am having difficulty installing SDM v2.5 on a 1841 router. I have connectivity to the router, I have a login with privilege level 15. I am able to telnet to and login to the router fine. However, when I run the SDM setup, it gives the error message that SDM was unable to connect to the router.
I sniffed the network and SDM does telnet to the router, login, and then goes into and exits config mode, and that is it.
I do not have SSH enabled, but I'm not aware that that is necessary to install SDM.
Solved! Go to Solution.
06-08-2009 04:02 PM
Try to move the files manually via TFTP to the router's flash. Full SDM requires following files:
sdm.tar
sdmconfig-modelnum.cfg
home.tar
home.shtml
common.tar
Hope it helps...
06-04-2009 03:25 PM
Any access-list and or access class configured on the router that may be preventing SDM access?
06-05-2009 11:50 AM
No, there are currently no access lists setup on the router at all. Nor is any sort of firewalling turned on on the host computer I am trying to install from.
06-08-2009 04:02 PM
sdm.tar
home.tar
home.shtml
common.tar
Hope it helps...
06-09-2009 09:28 AM
All of the files were already in the flash of the router except the sdm.tar file. I transferred this file, and now full SDM does appear to be running on the router. Thanks for the help.
