ISDN Dialer backup question
Answered Question
Jun 3rd, 2009
I don't have a lab environment available to test this at the moment, but I'm wondering...
If I have a dialer-list configured to look at an access-list to identify interesting traffic, if that access-list is not there, will the router just default to a permit any any similar to how it works if you apply a non-existant ACL to an interface? This should be a pretty easy one. Thanks in advance.
Correct Answer by Laurent Aubert about 7 years 7 months ago
Empty ACL is interpreted as permit any any or you will have an error message if the feature using it doesn't support it.
Laurent.
Overall Rating: 5 (1 ratings)
Correct Answer
Laurent Aubert Wed, 06/03/2009 - 11:21
Laurent.
