Login LMS 3.0 return page blank
oamiranda
I have problem to login on the homepage of LMS 3.0 returning blank page,even same with password incorrect.
There is a problem with your local password file. Shutdown Daemon Manager, then copy NMSROOT/lib/classpath/com/cisco/nm/cmf/servlet/orig/cwpass to NMSROOT/lib/classpath/com/cisco/nm/cmf/servlet/cwpass. This will reset your LMS password file to the default with only admin and guest as users. From there, you should be able to login as admin (with a password of admin), and recreate your users.
Joe Clarke
Post the NMSROOT/MDC/tomcat/logs/stdout.log, stderr.log, and the output of the pdshow command.
hello,
How to request.
What can happened to generate this problem.
