DTMF not working in UCCX using G729
Jun 3rd, 2009
After setting UCCX 7.0.1 to use G729 instead of G711 DTMF is not working. The topology is as follows.
PSTN > VzB SIP Trunk > 2811 Gateway > SIP Trunk > CUCM 7.0.2, UCCX 7.0.1
Anyone have any suggestions on where I should look to fix this?
Overall Rating: 0 (1 ratings)
Jonathan Schulenberg Wed, 06/03/2009 - 12:06
  • Cisco Designated VIP,
    2017 IP Telephony
You will need to add an MTP to the call path for this to work. CCX does not support RFC2833 or any other in-band DTMF method.
From the CCX 7.0 SRND, page 48, SIP Support section:
"Cisco Unified CCX CTI ports are notified of caller-entered digits (DTMF input) via JTAPI messages
from Cisco Unified CM. Cisco Unified CCX does not support any mechanism to detect in-band DTMF
digits where DTMF digits are sent with voice packets. In deployments with voice gateways or SIP
phones that only support in-band DTMF or are configured to use in-band DTMF, an MTP resource must
be invoked by Cisco Unified CM to convert the in-band DTMF signalling so that Cisco Unified CM can
notify Cisco Unified CCX of the caller-entered digits. Be sure to enable out-of-band DTMF signalling
when configuring voice gateways in order to avoid using the previous MTP resources. For detailed
design consideration related to DTMF handling, media resources and voice gateway deployments,
please refer the Cisco Unified Communications Solution Reference Network Design (SRND)."
Solution Reference Network Design for Cisco Unified CCX and Cisco Unified IP IVR, Release 7.0: http://cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_7_0/design/guide/uccx70srnd.pdf
