Problem adding 2 devices to LMS 3.1 - "Devices Not Configured In ACS"
Jun 3rd, 2009
I added 2 Cisco 3825 Routers to CiscoWorks. We use ACS (TACACS+) for authentication. The devices seemed to be added successfully, but in CM, they are showing as Devices Not Configured In ACS. I checked my ACS servers and the IP addresses are clearly in the TACACS+ group. Does anyone have any idea what is causing this?
Joe Clarke Wed, 06/03/2009 - 15:34
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Try restarting ACS and Daemon Manager. Assuming these two devices are in the same ACS NDG as other, working devices, there may just be a communications issue between LMS and ACS that a restart will fix.
stephenscott Thu, 06/04/2009 - 05:45
I stopped and started the services and now I can not launch RME.
I get the error: License Server/Daemon Manager is down. Please check license.log for more information.
I am attaching pdshow and regdaemon.xml
Thanks.
Joe Clarke Thu, 06/04/2009 - 08:51
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There are no problems here. This is most likely a timing issue. You should wait at least 30 minutes after restarting Daemon Manager for all of the daemons to initialize and the CPU to settle.
stephenscott Thu, 06/04/2009 - 09:42
I rebooted the server and all is well now...strange stuff.
