Cisco Agent Desktop CAD Language
Jun 3rd, 2009
My Contact Center Express is version 7.0 (1) Sr01_Buil210.
At the begin of the installation when they ask me at the Slection Windows : Cisco Unified Contact Center Express CAD and CSD Language....
I selected French and the customer want it in English! So now how can i change it ? Does I need to wipe the entire server OS and re-install from zero ? Any idea ?
Regard,
Louis
Overall Rating: 4 (1 ratings)
vkapoor5 Tue, 06/09/2009 - 06:26
  • Bronze, 100 points or more
Localization of Cisco Agent Desktop and Cisco Supervisor Desktop is driven by the language that you specified when installing CAD/CSD on the server. You should be able to rerun the installer and select a different CAD/CSD language without adversely impacting any other existing installation or configuration on the server.
lpaquin Tue, 06/09/2009 - 07:03
Thanks, i'll try to do it and see if it work.
