Justin Brenton Wed, 06/03/2009 - 15:56
  • Silver, 250 points or more
Hi Maiden013,
Is this Call Manager or Call Manager Express?
Also what version of Call Manager is this and What version firmware are you using?
Justin
Jaime Valencia Wed, 06/03/2009 - 17:09
  • Cisco Employee,
  • Hall of Fame,
    2011
Sound like calls using H323 with no MTP
java
if this helps, please rate
Alejandro Corte... Thu, 06/04/2009 - 04:39
Is call manager 6.1, all the MTP, CFB, Transcoding resources all configured in Software(ccm) and Hardware(gateway 3845).
Dennis Mink Thu, 06/04/2009 - 05:37
  • Blue, 1500 points or more
Have you got a MOH resource added to your MRGL?
Jaime Valencia Thu, 06/04/2009 - 06:24
  • Cisco Employee,
  • Hall of Fame,
    2011
MTP required checked in GW config?
MTP available in MRGL?
If you check the app log is it full of MTP errors??
java
Alejandro Corte... Thu, 06/04/2009 - 08:34
yes
yes
How can I see the log?
Justin Brenton Thu, 06/04/2009 - 06:44
What firmware version are your phone's using?
