jowolfer Wed, 06/10/2009 - 15:37
Stainless,
There is a "kick" command, but it is a hidden command intended for support troubleshooting.
If you are running into a scenario where you need to regularly restart the proxy process, I recommend filing a ticket with support and having the issue investigated further.
The proxy should never need to be manually restarted under normal conditions.
