system is offline. login will be queued until system is backonline
Jun 3rd, 2009
Dears,
Since posting my problem on the forum is fasted than a tac response, i prefered to post it here.
i know that this problem was faced before, but i checked the previous posts with no resolution.
when i try to login into the ctios agent i get the message: system is offline. login will be queued until system is back online.
the ctios server log is showing:
clientMgr[1]:onConnectionClosed, Client[00002]
XXX RCV Client[00002]: eOnConnectionClosed
Client[00002[: HandleI0: Connection closed.<ERROR_NETNAME_DELETED> ERROR:
0x00000040
normally there are two ctios servers A and B. but i shut sideB and just tried with the A. both cti, and ctios servers are up. but i'm not able to connect.
please help.
david.macias Thu, 06/04/2009 - 01:06
  • Blue, 1500 points or more
are your CG and CTIOS services active? Do you have your ctios client to connect to either side??
david
fabien.damien Thu, 06/04/2009 - 02:09
yes both services are up and ctios is listening to port 42028
thanks for your reply
david.macias Thu, 06/04/2009 - 04:27
bring up telnet and try to connect to IP 42028 and let us know what happens. Try this connection from the agents PCs.
david
fabien.damien Thu, 06/04/2009 - 05:15
thanks a lot david for you help, the problem was that the jtapi plugin was not installed on the PG.
fabien.damien Thu, 06/04/2009 - 06:08
the problem was that jtapi wasn't installed on the pg. regards
