Digital Signage components
Jun 4th, 2009
Hi All,
What components do I need to implement a digital signage solution for 20-40 endpoints on one LAN?
Can I use the DMP only or do i need a DMM to go along with them?Does the ISR require ACNS modules in this case(LAN)?
Appreciate your help on this.
Tomas De Leon Thu, 06/25/2009 - 06:27
  • Cisco Employee,
There is no simple answer for your question. There are alot of things to consider and you should contact a Cisco Account Team or Cisco Partner for different options regarding to you DMS needs.
That said.. I will address your question in the GENERAL sense...
You do NOT need a DMM to manage DMPs BUT with 20-40 Management, Configuration, & Scheduling tasks are made simpler and more efficient with a DMM.
ACNS is not required in a DMS solution. Depending on your Network Topology will determine your needs for Content Delivery systems. You state this is on a LAN not a WAN or Remote sites. Content can simply be stored on a Web Server(s) and the DMPs access URLs from there OR accessed via CIFS mounted drive.
As I mentioned before, please contact you local Cisco Rep for a more detailed assessment of your Needs..
Cheers!
T.
