06-04-2009 01:12 AM - edited 03-15-2019 06:21 PM
Hi all,
Any body can tell me how we can utilize the next NIC card on MCS servers.
Because I have on each server two NIC cards and I need to connect each card to switch, is that possible?
Solved! Go to Solution.
06-04-2009 01:46 AM
Assuming that you are running a Linux based product (CUCM 5/6/7, Unity Connection etc.) you need to go to the server console and issue the following command.
set network failover enable
This will set the second NIC to operate in standby mode - if the first NIC is disconnected the server will use the second NIC to communicate. Note only one IP address is used - it is not possible to have separate IPs on different interfaces.
Use show network failover to verify operation.
The NICs can be connected to separate switches as long as the switch ports are in the same VLAN/subnet.
Please rate if helpful.
06-04-2009 01:46 AM
06-04-2009 04:20 AM
PLease not that Cisco officially does not NIC pairing
(at least that is what I was told by a TAC engineer)
would be nice if someone from Cisco could comment on that, in this thread ;-)
06-04-2009 04:25 AM
Hey Dennis,
Here is a clip from Cisco that speaks to this question;
NIC Teaming Support
Server platforms with dual Ethernet network interface cards (NICs) can support NIC teaming for network fault tolerance with Cisco Unified Communications Manager. Cisco began support of NIC teaming on HP servers in the 5.0(1) release and began support on IBM servers in the 6.1(2) release. This feature allows a server to be connected to the Ethernet via two NICs and, hence, two cables. NIC teaming prevents network downtime by transferring the workload from the failed port to the working port. NIC teaming cannot be used for load balancing or increasing the interface speed.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_2/cucm-rel_note-612.html#wp412614
Hope this helps!
Rob
06-04-2009 02:11 PM
Thanks all
