size limitation for cookie size of HTTP header/cookie?
Answered Question
Jun 4th, 2009
Hi Everybody,
I am having 4 cisco ACE blades i.e 2 pairs and I have few questions when I am trying to configure stickiness and session persistence I am facing some issues for sticky table entry size
Is there any size limitation for cookie size of HTTP header/cookie?
what if it doesn't support large header/cookie size , is there any way to get the solution for this?
can somebody tell me what thing I am missing in my configuration?
RobertS
Correct Answer by sachinga.hcl about 7 years 8 months ago
Hi Robert,
Kindly find my comments there below to your questions:
I will try these in my lab apart from this I azm having few more question in my mind
How can I Verify that the load balancer (LB) is configured to load balance jpeg files.
My comment:
You can configure this
How to review the configuration of the load balancer in this situation; if the load balancer should be configured to balance requests based on the ASP.Net session id of the request or something else.
My comment:
Use a sniffer like wireshark or ethreal and check the static portion of Jsession-ID (usually its 10 bytes from offset 53). Following is the config for offset53,length10
sticky http-cookie JSESSIONID stitcky1
cookie offset 53 length 10
serverfarm APP1-SF
policy-map type loadbalance first-match APP1-POLICY
class class-default
sticky-serverfarm stitcky1
How will I define the max size of HTTP header is there any configuration document availble to do this ?
My Comment:
As I mentioned earlier, use sniffer like wireshark or ethreal and check the size of the header for regular traffic. If its more than the default ACE value then adjust it using parameter map by using header-maxparse-length set it to
parameter-map type http APP1_PARAM_MAP
set header-maxparse-length
And last question how should I define the load balancer fallback configuration if the HTTP header size is exceeded to the size you have suggested.
My Comment:
By default packet is dropped & RST is sent by ACE for closing the connection. If you want to change this behavior then use "length-exceed continue" to allow such packets through ACE module .
Sachin garg
Hi Robert,
If a cookie, HTTP header, or URL
exceeds the default value, the ACE drops the packet and sends a RST
(reset) to the client browser.
This behavior can be changed using "length-exceed continue", however
I dont recommend this.
Its better to increase the Header parse length to the header length expected by your app.
May be this can answer your query.
Thanks for your rating.
Sachin garg
Overall Rating: 5 (4 ratings)
sachinga.hcl Thu, 06/04/2009 - 03:48
Hi Robert,
See by default ACE can parse header of 4K Bytes . This default value can be changed using a http type parameter map.
The maximum an ACE can parse is 64K.
Following is an example to change it to maximum.
parameter-map type http PARAMETER_MAP_1
set header-maxparse-length 65535
then apply this parameter-map to the policy
policy-map multi-match ABC
class ABC
loadbalance vip inservice
loadbalance policy xxx
loadbalance vip icmp-reply
appl-parameter http advanced-options PARAMETER_MAP_1
For any further discussion plese dont hesitate to ask further.
Sachin garg
robertsmith.net... Thu, 06/04/2009 - 03:51
Hi Sachin,
Thanks for your fast response!!
If incase the http header exceeds 4k Bytes as you told me what will happen to the persistence? will it go to sticky by IP or not?
Is there any way we can setup session using ASP.NET session ID ?
Any document or link in this regard will be helpful
RobertS
Correct Answer
sachinga.hcl Thu, 06/04/2009 - 03:53
Hi Robert,
Sachin garg
robertsmith.net... Thu, 06/04/2009 - 04:02
Hi Sachin,
I will try these in my lab apart from this I azm having few more question in my mind , will be great to hear some guidelines from you in this regard?
And last question how shoud I define the load balancer fallback configuration if the HTTP header size is exceeded to the size you have suggested.
BTW Thanks you all for solving it so fast.
Roberts
Correct Answer
sachinga.hcl Thu, 06/04/2009 - 04:10
Hi Robert,
My comment:
My comment:
serverfarm APP1-SF
class class-default
My Comment:
My Comment:
Sachin garg
robertsmith.net... Thu, 06/04/2009 - 04:12
Hi Sachin,
Thanks for your all replies.
As I am going to try all these options in my lab before making these changes to my production servers.
This is enough guidelines for my all queries as for now.
As once I will be reading mor eI will come up p with some more queries.
Thanks for your all fast responses.
RobertS
sachinga.hcl Thu, 06/04/2009 - 04:15
Hi RobertS
Can you send me your config so that I can see what actually you have configured on your all 4 ace blades.
Sachin garg
robertsmith.net... Thu, 06/04/2009 - 04:17
Hi Sachin,
Kindly Find below my config for your perusal:
Generating configuration....
access-list ICMP-INSPECT line 100 extended permit icmp any any
access-list INSIDE_IN line 10 extended permit ip any any
access-list OUTSIDE_IN line 10 extended permit ip any any
probe tcp tcp-7500
port 7500
interval 5
passdetect interval 5
parameter-map type connection NET-CONN-PARAMS
set tcp buffer-share 65535
tcp-options timestamp allow
no random-sequence-number
parameter-map type ssl SSL-WebEx-COM
cipher RSA_WITH_RC4_128_MD5 priority 6
cipher RSA_WITH_RC4_128_SHA priority 6
cipher RSA_WITH_DES_CBC_SHA priority 4
cipher RSA_WITH_3DES_EDE_CBC_SHA priority 5
cipher RSA_WITH_AES_128_CBC_SHA priority 7
cipher RSA_WITH_AES_256_CBC_SHA priority 7
cipher RSA_EXPORT_WITH_RC4_40_MD5 priority 3
cipher RSA_EXPORT1024_WITH_RC4_56_MD5 priority 3
cipher RSA_EXPORT_WITH_DES40_CBC_SHA priority 3
cipher RSA_EXPORT1024_WITH_DES_CBC_SHA priority 3
cipher RSA_EXPORT1024_WITH_RC4_56_SHA priority 3
rserver host test01
ip address 100.124.75.210
inservice
ssl-proxy service qa_ssl
ssl advanced-options SSL-WebEx-COM
serverfarm host ahz_wallice_testonepool-7500
probe tcp-7500
rserver test01 7500
inservice
sticky http-header F5_CREDENTIAL sticky_wallice_header
timeout 2
serverfarm ahz_wallice_testonepool-7500
class-map match-all ICMP-INSPECT
2 match access-list ICMP-INSPECT
class-map match-all cL4_ahz_wallice_testone-7500
2 match virtual-address 10.224.179.20 tcp eq 7500
class-map match-all cL4_ahz_wallice_testone-80
2 match virtual-address 10.224.179.20 tcp eq www
class-map type management match-any remote-access
2 match protocol telnet any
3 match protocol ssh any
4 match protocol http any
5 match protocol icmp any
6 match protocol snmp any
policy-map type management first-match remote-mgmt
class remote-access
permit
policy-map type loadbalance first-match pL7_ahz_wallice_testone-7500-header
class class-default
sticky-serverfarm sticky_wallice_header
policy-map type loadbalance first-match pL7_ahz_wallice_testone-7600
class class-default
policy-map multi-match ICMP-INSPECT
class ICMP-INSPECT
inspect icmp error
policy-map multi-match NET-CONN-PARAMS
class class-default
connection advanced-options NET-CONN-PARAMS
policy-map multi-match pL4_ahz_wallice_testone
class cL4_ahz_wallice_testone-7500
loadbalance policy pL7_ahz_wallice_testone-7500-header
nat dynamic 100 vlan 911
class cL4_ahz_wallice_testone-80
interface vlan 911
description Internal
ip address 10.224.179.209 255.255.255.240
access-group input INSIDE_IN
nat-pool 100 10.224.179.210 10.224.179.210 netmask 255.255.255.255 pat
service-policy input remote-mgmt
service-policy input NET-CONN-PARAMS
service-policy input ICMP-INSPECT
service-policy input pL4_ahz_wallice_testone
no shutdown
interface vlan 912
description External
ip address 10.224.179.206 255.255.255.240
access-group input OUTSIDE_IN
no shutdown
ip route 0.0.0.0 0.0.0.0 10.224.179.205
ip route 100.124.75.210 255.255.255.0 10.224.179.221
Ace_West/Infra#
RobertS
