WCS WLAN Override
Jun 4th, 2009
I have a WCS with version 4.0.97.0 and two controllers with version 4.0.217.0. and two models APs: AIR-LAP1242AG-E-K9 and AIR_LAP1131AG-E-K9.
The problem is that I am unable to configure the templates WCS WLAN Override.
I can set the controllers but when I try to sync through the WCS => Controller Commands => Configuration Commands => Refresh Config from Controller, it does not work fine and it deletes or change the WLAN Override.
What can I do? An upgrade?
Dirk Woellhaf Tue, 06/09/2009 - 02:17
updating maybe solve your issue but when you upgrade to a version beyond 5.x "WLAN Override" is no longer supported, I think.
You have to use "AP-Groups" to override to default setting.
This works perfect for me (Using WCS 5.2.130.0)
regards Dirk
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
