%FIB-4-FIBCBLK: Missing cef table
Jun 4th, 2009
Is anybody familiar with this message:
%FIB-4-FIBCBLK: Missing cef table for tableid 65535 during CEF samecable event
The router keeps reporting this constantly.
If you would also happen to know how to fix this it would be great thanks.
2 votes
Giuseppe Larosa Thu, 06/04/2009 - 05:00
Hello Rocco,
the error message decoder provides the following feedback:
2. %FIB-4-FIBCBLK: Missing cef table for tableid [dec] during [chars] event
An internal software error has occurred.
Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://tools.cisco.com/Support/BugToolKit/action.do?hdnAction=searchBugs. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://www.cisco.com/cgi-bin/front.x/case_tools/caseOpen.pl, or contact your Cisco technical support representative and provide the representative with the information you have gathered. Attach the following information to your case in nonzipped, plain-text (.txt) format: the output of the show logging and show tech-support commands and your pertinent troubleshooting logs.
And the tool suggests also the following link for CEF error messages troubleshooting:
according to the document you may be hitting the following bugs:
Cisco bug IDs CSCsg03483 and CSCee26209 d
Hope to help
rdeangel Thu, 06/04/2009 - 05:13
Thank for the links Giuseppe,
I found the following for a similar errors:
CSCee26209 Bug Details
Symptoms: When removing "ip vrf" from the configuration, the following message
is printed:
%FIB-4-FIBCBLK: Missing cef table for tableid 1 during CEF table change event.
This is also triggered when configuring a NPE-G1 interface with a vrf.
Conditions: Simple configuration with no routing protocols running.
Workaround: not known. But there is no expected impact which should
be expected from those error messages.
I don't think there is a workaround for my issue either.
However this error seems to cause no real effect.
