06-04-2009 04:56 AM - edited 03-06-2019 06:06 AM
I got this message after i reload it "!!! WARNING: The switch is not usable !!!", i made a IOS UPDATE before the "reload", when i tried to roll back the IOS the switch doesn't works, the same message was displayed.
See attached the Switch initialization.
06-04-2009 07:26 AM
This tells me you might have a H/W problem.
POST: PortASIC CAM Subsystem Tests : Begin
HTD POST: Basic Test Failed
POST: POST Failed
POST: PortASIC CAM Subsystem Tests : End, Status Failed
you could format flash and upload old IOS via console and see if it works. a faster way to find out would be to replace existing flash with one that has your old IOS if at all possible.
Sam
Sam
06-04-2009 03:17 PM
The ASIC has failed during POST. I recommend you contact Cisco to get the product RMA-ed.
If you are lucky, sometimes you can get a 10 Business Day lifetime warranty on the appliance.
Hope this helps.
