CSM 3.2 Upgrade Path
Jun 4th, 2009
I recently installed CSM 3.2 and am looking at the software and see several upgrades. The most current appears to be 3.2.2 SP2. Can I upgrade directly to this version? If not what upgrade path should i follow?
pmccubbin Tue, 06/09/2009 - 07:15
  • Silver, 250 points or more
Hi Doug,
Yes, you can upgrade directly. Here is the answer found in the Release Notes:
"Service pack 2 is a cumulative update that also includes the updates that
were found in service pack 1. You can apply Cisco Security Manager 3.2.2
Service Pack 2 to a Cisco Security Manager 3.2.2 installation whether
that installation has service pack 1 installed or not."
Hope this helps.
Best,
Paul
