routing between firewalls
Jun 4th, 2009
I have a couple of ASA's on the same network, one pointing to the internet and a second pointing to other networks. The problem i have is if i use the internet ASA as the default gateway i cannot communicate with the other networks through the second ASA. Is there something which stops routes being redirected out the same interface.
Many thanks in advance
keith.osullivan Fri, 06/05/2009 - 09:32
the firewalls can run routing protocols, will that solve the problem until i am able to change my topology?
Many thanks
