MeetMe Conference Time Limit./Timeout
Jun 4th, 2009
Is there a service parameter in 6.1 that specifies the maximum time for a MeetMe conference?
I have a customer that reported that MeetMe Conferences end after about 5 Hours.
Overall Rating: 5 (1 ratings)
rob.huffman Fri, 06/05/2009 - 09:30
Hi Rob,
You are hitting this CUCM Service Parameter Config which will control how long this MeetMe Conference will stay up. This setting is also applied to all Incoming and Outgoing CUCM calls;
Clusterwide Parameters (Feature - General)
Maximum Call Duration Timer :
This parameter specifies the minutes that a call can remain active before Cisco CallManager clears it. A value of zero disables the timer.
This is a required field.
Default: 720.
Unit: min.
Minimum: 0.
Maximum: 35791.
Hope this helps!
blackswans Tue, 06/09/2009 - 22:08
But this also effects all other calls. Is there any value that limits only the meetme conf duration? Is it coming with 7.0 version?
rob.huffman Wed, 06/10/2009 - 04:39
Hi Okan,
Yes, sadly this does effect all calls :( I'm very sorry if my note in the first post was not clear my friend;
"This setting is also applied to all Incoming and Outgoing CUCM calls"
I have not seen the ability to change this for only Conference calls on any current CUCM version including the newly released CUCM 7.1(2)
