ICM Parent Child on different versions
Jun 4th, 2009
Hi All,
I was wondering whether we could have the ICM parent and child running on different versions? Is there any Cisco document which throws some light on the same?
Overall Rating: 5 (2 ratings)
Michael Owuor Thu, 06/04/2009 - 21:26
  • Cisco Employee,
Suman,
Its currently not clearly documented. CSCsu61423 is open to address this concern.
The current general guideline would be that the (parent) Gateway PG version should match that of the System PG it communicates with. At a minimum, the major and minor versions should be the same.
One a separate note, in general, PGs are supported two major versions back relative to their Central Controller in upgrade or migration purposes.
I hope this helps.
Michael.
