QoS policy-map - no stats
Jun 4th, 2009
I'm having issues getting what I thought would be a very simple QoS policy to work. I've created an ip match any any ACL and applied it to a class-map and then tioed it to a policy, followed by assigning it to an interface. However I can't get any matches to occur against the policy so I'm sure I've missed soemthing very fundamental. The key output is included below. Can anybody advise why I'm not getting any matches against the any any ACL and hence the policy map? I've a feeling I've missed something really basic by looking at all for too long!
3750# sho run | inc mls
mls qos
3750#sho access-list
Extended IP access list 199
10 permit ip any any (101 matches)
3750## sho class-map
Class Map match-any TEST (id 6)
Match access-group 199
Class Map match-any class-default (id 0)
Match any
3750#sho policy-map
Policy Map TEST-PM
Class TEST
set dscp cs7
Class class-default
set dscp 1
3750#sho policy-map int
GigabitEthernet1/0/5
Service-policy input: TEST-PM
Class-map: TEST (match-any)
0 packets, 0 bytes
offered rate 0 bps, drop rate 0 bps
Match: access-group 199
0 packets, 0 bytes
rate 0 bps
Class-map: class-default (match-any)
0 packets, 0 bytes
Match: any
0 packets, 0 bytes
rate 0 bps
3750#sho access-list 199
3750#sho run int gi1/0/5
Building configuration...
Current configuration : 194 bytes
interface GigabitEthernet1/0/5
switchport access vlan 100
srr-queue bandwidth share 1 70 25 5
srr-queue bandwidth shape 3 0 0 0
priority-queue out
service-policy input TEST-PM
end
3750#sho vers
Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 19:15 by nachen
Image text-base: 0x00003000, data-base: 0x01080000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEE4, RELEASE SOFTWARE (fc1)
whp-cab0-sw07 uptime is 18 weeks, 1 day, 5 hours, 19 minutes
System image file is "flash:c3750-ipbase-mz.122-35.SE5/c3750-ipbase-mz.122-35.SE5.bin"
cisco WS-C3750G-24TS-1U (PowerPC405) processor (revision E0) with 118784K/12280K bytes of memory.
jedellerby Fri, 06/05/2009 - 01:25
I think I've worked out what the issue is with my approach. The show policy-map interface command does not report any useful stats. The actual QoS policy config I applied was fine, albeit the version above is not that useful.
Looking at the 3550 config guide:
"Do not use the show policy-map interface privileged EXEC command to display classification information for incoming traffic. The interface keyword is not supported, and you should ignore the statistics shown in the display. Instead, you should specify the DSCPs to be monitored by using the mls qos monitor dscp dscp1 ... dscp8 interface configuration command, and then you should use the show mls qos interface interface-id statistics privileged EXEC command. For more information about these commands, see the command reference for this release."
In my case I'm using a 3750 and the above issue is not mentioned in the 3750 QoS config doc but I suspect the same problem applies. So, to solve the stats issues I tried looking at the "show mls qos interface statistics" instead and I could see appropriate matching stats.
As a true real world test i tried policing the voice traffic whilst on a call and it most certainly throttled the traffic. It was surpring to see that I needed nearly 80kbps to allow a G711 call to work effectively, I thought it would be okay at 60-70kbps so it was good to see exactly how sensitive it is to packet loss.
Jed
