Deleting vlan Database on 6500 running IOS
Answered Question
Jun 4th, 2009
Trying to delete the vlan database on a 6500 running IOS.
Please help.
Jeremy
Correct Answer by lamav about 7 years 10 months ago
Hi:
do a "dir all-files"
Find the directory where the vlan.dat file is found and delete it.
example:
del nvram:vlan.dat
Overall Rating: 5 (2 ratings)
Jon Marshall Thu, 06/04/2009 - 14:38
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jeremy
erase const_nvram:/vlan.dat
Jon
anjery1234 Thu, 06/04/2009 - 15:57
Jon,
Not sure what I'm doing wrong.
All appeared fine but the command won't work. The code I'm running is s72033-ipservicesk9-mz.122-18.SXF5.bin
bkbb-rp01#erase const_nvram:/vlan.dat
% Invalid input detected at '^' marker.
bkbb-rp01#dir con
bkbb-rp01#dir const_nvram:
Directory of const_nvram:/
1 -rw- 0 vlan.dat
129004 bytes total (129004 bytes free)
Correct Answer
lamav Thu, 06/04/2009 - 17:31
  • Blue, 1500 points or more
Hi:
example:
del nvram:vlan.dat
Jon Marshall Fri, 06/05/2009 - 00:00
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jeremy
Just try
6500# erase const_nvram:
If that doesn't work
6500# erase ?
do you get the option to erase the const_nvram: ?
Jon
anjery1234 Fri, 06/05/2009 - 04:09
Jon,
This first command was the good one.
I just needed to set my vtp mode to server.
Thanks a lot
