CVPND never runs on Vista anymore
Answered Question
Jun 4th, 2009
Hi all. I've been using Cisco VPN client 5.0.02 for work for a while now on Vista. However, I recently upgraded to Vista SP2. Now, when I try to start the client, I get the error:
Error 56: The Cisco Systems, Inc. VPN Service has not been started. Please start this service and try again.
I can see that the daemon service isn't running. When I start it, however, it stops straight away.
I've tried to enable logging up adding the following to the vpnclient.ini file:
[main]
EnableLog=1
[LOG.IPSEC]
LogLevel=15
[LOG.IKE]
LogLevel=15
[LOG.CVPND]
LogLevel=15
But I never get any log. Is there any way I can debug what's going on in the CVPND, so I can get it to run again?
Thanks for any help,
Ed
Correct Answer by Farrukh Haroon about 7 years 8 months ago
Please try the following:
Stop the ICS (Internet Conn. Sharing) service. Make its Startup Type to MANUAL. Restart Cisco VPN Client Service.
If that does not work:
Uninstall the client, delete all registry keys associated with client, reboot, re-install.
Farrukh
Overall Rating: 5 (1 ratings)
Correct Answer
Farrukh Haroon Sat, 06/06/2009 - 23:50
Farrukh
edhillmann Sun, 06/07/2009 - 02:02
This worked for me. Now that I've disabled the ICS, I can connect.
Thanks for the help,
Ed
Farrukh Haroon Sun, 06/07/2009 - 02:11
I'm glad its working now Ed.
Please rate if you find the solution helpful.
Farrukh
