Cannot remove trustpoint from ASA
Answered Question
Jun 4th, 2009
I am trying to clear out all the trustpoints on my ASA to reconfigure the ASA phone-proxy. However, I cannot remove the ctl-file asdm_CTL_File.
When I enter the command clear configure crpyto ca trustpoint I receive this error.
ERROR: The trustpoint phoneproxy_trustpoint appears to be in use. Unable to remove this trustpoint.
ERROR: Trustpoint cannot be removed There are 1 open sessions.
ERROR: The trustpoint _internal_PP_asdm_CTL_File appears to be in use. Unable to remove this trustpoint.
INFO: Be sure to ask the CA administrator to revoke your certificates.
I'm sure it's one or two commands that I am missing. Any help would be great.
Correct Answer by husycisco about 8 years 1 month ago
Hello Brett
Have you tried removing CA certificate first?
clear configure crypto ca certificate "certname"
Also try clearing crls
clear crypto ca crls
An IPSEC transform-set in use by a crypto-map, containing RSA may also be causing this. Try removing the transform-set first
Overall Rating: 5 (1 ratings)
Correct Answer
husycisco Sat, 06/06/2009 - 03:51
  • Gold, 750 points or more
Hello Brett
Farrukh Haroon Sun, 06/07/2009 - 01:45
  • Red, 2250 points or more
If this issue is still not solved, do a "show tls-proxy sessions" and clear any in-use sessions.
Farrukh
Farrukh Haroon Fri, 06/12/2009 - 21:36
Please mention which command specifically solved your problem.
Please rate any solutions if you find them helpful.
Farrukh
