Configure SIP with CLI
m.junghage
Hi!
I'm trying to get the UC500 to work with our SIP providers. Since I'm in Sweden I can't use the fancy preconfigured SIP providers.
I can't get it to work when doing it in the CCA 2.0. I wan't to se exactly how it's setup and if it registers with the provider.
How do I set up a SIP trunk from the CLI?
How to monitor the registration?
In CCA 2.0 you get the option to authenticate on user level instead of digest authentication. Does this mean that I can use a provider that issues usernames and password for each telephonenumber? The provider in this case is Telia.
Thanks!
Maulik Shah
Level 5
Level 5
A CLI guide is here:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_example09186a00808f9666.shtml
Also, you can read section 4.4 at
https://www.myciscocommunity.com/servlet/JiveServlet/previewBody/1560-102-1-1933/UC500-SIPTrunking-Wiki-062008.pdf
Yes you can have a username / password pair per phone number for Registration purposes, support for extending this to INVITEs is on our roadmap.
