RVS4000 and bandwidth usage?
Jun 5th, 2009
I have a customer who recently bought a RVS4000 router (firmware 1.2.11). The customer is hooked up on a 50/50Mb fibre connection but the maximum bandwidth the customer can get out of the RVS4000 router is 18/18Mb. The 50/50Mb connection is working fine, the speed has been measured to be correct.
According to the Data Sheet the router should be able to support 1000Mb.
Here's the question - what should be done to get the router working on full speed?
kind regards,
Rasmus Almqvist, Territory Market Manager
Phone: +358 40 774 6719
Email: rasmus.almqvist@cisco.co
m
Te-Kai Liu Wed, 06/10/2009 - 19:16
The router has IPS (Intrusion Prevention System) enabled by default. If IPS is disabled, you could see higher throughput.
