Presence 7.0 question
Jun 5th, 2009
We are deploying presence in a UCM 7.0(2) cluster. We have UCM integrated with Microsoft AD (both synchronization and authentication). The only problem were having after completing all integration steps is the voicemail piece to unity connection. Since we are integrated with LDAP, we cannot change user web passwords in unity connection. It is this password that users set in CUPC in order to hook into Unity Connection.
Can someone tell me given our ldap integration, where we can set this web password so CUPC users can integrated into Unity Connection? When we try to modify web password in Unity Connection, error shows up that it's not allowed as were using ldap authentication.
thank you
htluo Fri, 06/05/2009 - 04:26
  • Red, 2250 points or more
Isn't the web password the LDAP password?
To configure the password on CUPC side, you can go to File -> Preferences -> Accounts.
Michael
http://htluo.blogspot.com
