Binding MAC to IP using client-identifier
Jun 5th, 2009
I have 10 PCs on the network to which I want to allocate fix/specific IP from DHCP server configured on my 3825 Router. Currently I am using IP Pool & "client-identifier". Problem is that, for every Host/IP I need to create separate Pool. Is there any procedure via which I need not to create separate pool for separate IPs/Hosts. Below is the snap of Configs for ref.
ip dhcp pool fixip-1
host 192.18.144.104 255.255.254.0
client-identifier 0100.2170.7b7c.ca
lease 7
ip dhcp pool fixip-2
host 192.18.144.105 255.255.254.0
client-identifier 0100.1b24.6190.ab
lease 7
ip dhcp pool fixip-3
host 192.18.144.106 255.255.254.0
client-identifier 0100.219b.e562.fd
lease 7
ip dhcp pool fixip-4
host 192.18.144.107 255.255.254.0
client-identifier 0100.0e7f.a421.af
lease 7
ip dhcp pool fixip-5
host 192.18.144.108 255.255.254.0
client-identifier 0100.23ae.015f.23
lease 7
cisco_lad2004 Fri, 06/05/2009 - 06:47
DHCP option 82 will do the trick....but then you need a dedicated DHCP server.
Sam
