Issues bridging two AIR-BR1310Gs
Answered Question
Jun 5th, 2009
I have configured two 1310s as per this (http://cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008058f53e.shtml). The association appears to have taken place (both APs say in their logs), but I am now unable to connect to them over IP or ICMP.
I've attached the configs for review. What am I missing here?
Correct Answer by jeff.kish about 8 years 1 month ago
Try copying and pasting your WEP key again, maybe it got changed somehow. Also, shouldn't aaa new-model be enabled on the non-root? AAA is sadly not my specialty, so I don't know if it's required in this scenario.
What I would do at this point is start removing security until it works. Get rid of RADIUS authentication first and see if they connect. Then get rid of the WEP key and see if that works. Hopefully you'll find out why they aren't working this way. At that point, at least know what you're troubleshooting.
Give that a try and let me know how it goes.
Jeff
Overall Rating: 5 (1 ratings)
Correct Answer
jeff.kish Fri, 06/05/2009 - 05:29
  • Silver, 250 points or more
Jeff
jeff.kish Fri, 06/05/2009 - 07:02
Gah, AAA does it again.
Thanks, and glad that worked!
