CUCM 7.0 & Avaya SIP trunk problem
parshah Fri, 06/05/2009 - 11:14
  • Cisco Employee,
Can you provide CallManager traces for this failed call.
Also, please ensure that your region settings is g.711 throughout CUCM, especially for the SIP call. Also, do you have MTP required checked on the SIP trunk.
parshah Sun, 06/07/2009 - 12:00
  • Cisco Employee,
The attachment you sent does not have the proper info. From the link I sent you, you will see that you need to set the trace level for SDI and SDL. For both you will see there are check boxes, please make sure that you have checked all the check boxes that have 'SIP' in it. From the trace you have sent, I don't see any SIP messages, so looks like SIP checkbox was not checked.
Please check the appropriate boxes and upload both SDI and SDL traces for the recreated issue. You can zip them and upload them.
