Access Point issues
Jun 5th, 2009
I have six AIR-LAP1252AG-E-K9 access points. Users have complained about connection issues. I have noticed in the last three days that certain access points stop working. They just don't allow clients to associate until they are rebooted. Then they work fine. I have resetall of them at least once, but two of them just stop functioning properly. Can anyone tell me why this is? It is not efficient to keep rebooting them.
ehlers.kevin Fri, 06/05/2009 - 07:22
You could be running into this nasty bug CSCsz05479. It affects both 1250s and 1140s.
"Symptom: An AP1252 may be seen to stop emitting frames, i.e. stop forwarding data from the LAN to the wireless channel."
Vinay Saini Sat, 06/06/2009 - 23:46
Hii ,
Please login to AP and issue the command "show controller d1" and check the state of Beacons and Probes . If both are enabled and you can see any beacons or frames on air , you might be hitting some bug.
Which code you are using ?
RVirdi Fri, 07/17/2009 - 00:05
I apologise only replying to one of the messages.
The APs are running:
Software Version
Boot Version
IOS Version 12.4(13d)JA
Mini IOS Version
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
