06-05-2009 05:57 AM - edited 03-06-2019 06:07 AM
What should be considered when deciding how many routers can be allowed in an OSPF area? Is there a Cisco article which explains these issues?
Solved! Go to Solution.
06-05-2009 10:17 AM
Hello George
OSPF design guide has a small section briefing the points to be considered when designing the number of routers in an OSPF area:
http://www.cisco.com/en/US/tech/tk365/technologies_white_paper09186a0080094e9e.shtml#t40
Refer to this guide.. with regards to the max no of routers, it really depends. there are lots of sources saying different values, but it really matters on the points given in the OSPF design guide. how many routers are you planning to put?
HTH.. all the best. rate replies if found useful..
Raj
06-05-2009 10:17 AM
Hello George
Raj
