Site to Site VPN MTU Error
Jun 5th, 2009
I was playing around with SDM on my router and tested my VPN tunnel. I got the following error:
Failure Reason(s)
A ping with data size of this VPN interface MTU size and 'Do not Fragment' bit set to the other end VPN device is failing. This may happen if there is a lesser MTU network which drops the 'Do not fragment' packets.
Recommended Action(s)
1)Contact your ISP/Administrator to resolve this issue.
2)Issue the command 'crypto ipsec df-bit clear' under the VPN interface to avoid packets drop due to fragmentation.
The VPN works fine though. I found this on Cisco: http://www.cisco.com/en/US/tech/tk801/tk703/technologies_tech_note09186a0080094c4f.shtml I tried applying it to my ethernet interface that is connected to my cable modem, but I still got the error when testing. Do I need to reboot or do I need to apply to that command to another interface? I tried setting it to 1420 and 1200. Still got the error when testing. Thanks!
Richard Burts Fri, 06/05/2009 - 09:54
Mike
The article for which you gave the link has several suggestions. You have not specified which of the several suggestions that you used. The suggestion that I find the most useful is to use the ip tcdp adjust-mss command and I will assume that this is what you did. If not clarify what you did and we will start over again.
I find that ip tcp adjust-mss is effective in resolving the fragmentation issue for a lot of traffic going through VPNs. But it is effective only for TCP traffic. Since the error message in the SDM test specifies that it is using ping (not part of TCP) then the SDM test would still see an error even though your VPN is working pretty well. There is no need to reboot. The only other commands that I can think of would be the commands listed in the article to adjust the MTU (and I do not believe that they are worth it).
Rick
MikeTomasko Fri, 06/05/2009 - 11:27
ip tcp adjust-mss is the command I tried on several of my interfaces. Still got that 1 send error.
This is all for a test lab and I was just playing with SDM and found the tunnel test. So you think it's nothing worth worrying about trying to fix?
Richard Burts Fri, 06/05/2009 - 11:31
Mike
If the only symptom is that the SDM test complains, then I do not believce that it is worth trying to fix it. If there are other symptoms then perhaps it might be worth it.
Rick
