Switch Comparison for Compatibility
iyde Fri, 06/05/2009 - 07:34
  • Silver, 250 points or more
No.
Obviously you won't have PoE on the new switch but that ahs nothing to do with the stacking.
Ingeneral, any Cat3750 can be put into a stack with other Cat3750, and by doing that you can get the various interface types you might need.
HTH.
Joseph W. Doherty Fri, 06/05/2009 - 08:37
As Ingolf notes, in general you can mix any model 3750 within the same stack.
The only compatiblity issue that comes to my mind is the fiber only 3750 supports a SDM template not supported by the other models. (You can still mix models, but need to insure the special template isn't configured.) However, this shouldn't arise for your noted models.
