Dial from Ethernet
Jun 5th, 2009
Hi Everbody,
Is there any way or configuration is there to dial a telephone number from Ethernet Interface of the router.
I have a CDMA phone having RS232 Interface, connnected to RS232 to Ethernet convertor, and in turn connected to 1841 Router ethernet fa0/0 Interface.
I am trying to dial a number from the router. Iam aware that if i have a serial interface i can do that. But from ethernet interface how it has to be done
thanks in advance
Paolo Bevilacqua Fri, 06/05/2009 - 07:55
Refer to your "ethernet to rs232" converter documentation for how to use it.
All the other devices do not matter at all.
hclisschennai Fri, 06/05/2009 - 08:59
It is just a converter. No configuration is possible in that device.
I am trying to configure dialer in the ethernet interface. Is that possible?
hclisschennai Fri, 06/05/2009 - 10:22
It is RS232 to Ethernet converter.
Cant i configure dialer interface on ethernet as we do for PPoE?
Paolo Bevilacqua Fri, 06/05/2009 - 10:25
No. Sorry, it seems like you have no basic understanding of networking and how these devices work.
Giuseppe Larosa Fri, 06/05/2009 - 12:03
Hello R.B. Kumar,
having a converter is not enough:
to interface to a phone network also called PSTN you need a setup that emulates OSI layer 1, 2, and 3.
For example an ISDN interface used for voice supports:
the standards for the BRI or PRI interface
the Q.921 that describes the L2 level
the Q.931 used on the signalling channel: it is this component that makes the difference.
so the converter you have is good only for data services but it misses all the signalling components needed to interface to PSTN
Hope to help
