ASA SSH to PIX
Answered Question
Jun 5th, 2009
Hi All,
I have site to site VPN between ASA and PIX. I want to connect to PIX by ssh or telnet through ASA. I know we can do this in router with "telnet" command. is there any way to connect to PIX through ASA by SSH or telnet?
thanks for any suggestion.
Alex
Correct Answer by srue about 7 years 11 months ago
no. the asa and pix do not have either a telnet or ssh client.
Overall Rating: 5 (1 ratings)
alex goshtaei Fri, 06/05/2009 - 09:47
Thanks for the reply,
how about connect to PIX by ASA command line?
the problem is PIX is only allow SSH access from inside interface not outside. I don't have access to the inside of PIX. I want to connect to PIX by SSH to the PIX inside IP address in the ASA command line.
also I don't have access to any host inside ASA.
is this possible?
thanks
Alex
Correct Answer
srue Fri, 06/05/2009 - 10:19
  • Blue, 1500 points or more
Kureli Sankar Fri, 06/05/2009 - 10:32
  • Cisco Employee,
For security reasons, it is by design that you cannot telnet or ssh from the firewall.
