06-05-2009 10:47 AM - edited 03-14-2019 04:11 AM
Call Center management requires a report showing the calls for agents (summaries) with wrap-up codes. Looked high + low - could not find a single report which shows wrap-up codes by agent. NEED THIS REPORT....Help
06-05-2009 10:54 AM
There is no precanned report for WrapUp Codes, you must write a report to perform this action.
06-05-2009 11:12 AM
Is there a Cisco interface within WebView to generate a custom report?
06-05-2009 11:19 AM
I need to clarify - is there a built-in tool to generate a webview report per agent using the wrap-up codes that summarizes their call totals, talk time etc by wrap-up code. I find conflicting information (old) that teases you into thinking these reports are available...but when you check, they are not.
06-05-2009 11:50 AM
You will need to buy Sybase InfoMaker, which will allow you to modify the current WebView templates.
david
06-05-2009 10:51 PM
This question comes up a lot on this forum. Search here and look at some old posts on the subject.
The wrap up code is NOT a code - it's actually called WrapupData (varchar 40) in the TCD. It is not indexed through a number (a code) and is not summarised in half hour tables. It's raw data in a table you should not search on a live system.
Please be aware of the limitations before proposing a solution to your customer.
Geoff
