Default MOH files
Answered Question
Hello, I am working an older Call Manager System 4.0 and found that when it was installed it was installed with only one "The Boys from Liverpool" MOH file. Which now one here likes and of course I open my mouth and tell them there should be other choices. NOT!
Does anyone know the link to download the basic comes with the systems MOH files?
Thanks for the help.
Jon
Correct Answer by James Hawkins about 8 years 1 month ago
Jon,
Older versions of CCM shipped with an MoH Selections CD which contained a range of tracks including Boys from Liverpool.
From memory Cisco announced that they would no longer be shipping this CD with new versions of CCM as they were constantly being pursued by the Performing Rights Society for royalties despite the fact that Cisco had actually commissioned and paid for the tracks.
If you cannot find the CD you can download royalty free tracks from sites such as:
http://www.royaltyfreeclassicalmusic.co.uk/
You may need to convert the file format for use by CCM. I use Switch Sound File Converter from NCH Software for this purpose.
http://www.nch.com.au/switch/index.html
Please rate if helpful.
Overall Rating: 5 (1 ratings)
Rob Huffman Fri, 06/05/2009 - 12:18
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jon,
Try the last one on this page (these are the only ones available still for download) :)
http://www.cisco.com/pcgi-bin/swsrch/SWSearch_results.cgi/SWSearch_results.cgi/SWSearch.txt?isChild=false&file_delimiter=contains&searchPhrase=music
Hope this helps!
Rob
Correct Answer
James Hawkins Mon, 06/08/2009 - 00:13
  • Blue, 1500 points or more
Jon,
