error message Servfail
Hi Experts,
If i try to nslookup directly with GSS ip address. I do get a responce with vip ip address.
When i use my local dns server.. where i have an entry to saying my authorative server for domain is GSS.
If use the dns server ip address is not resolving. I see the following message in tcp dump of GSS.
12:58:42.183691 IP (tos 0x20, ttl 55, id 0, offset 0, flags [DF], proto 17, length: 65) y.y.y.y.24275 > [udp sum ok] 27757 A? (37)
12:58:42.184066 IP (tos 0x0, ttl 64, id 343, offset 0, flags [DF], proto 17, length: 65) > y.y.y.y.24275: [bad udp cksum 36e!] 27757 ServFail- q: A? 0/0/0 (37)
Request is coming to GSS but it is not sending out vip ip address..
Gss working on Version 3.0(2)
Any idea ?
Overall Rating: 5 (1 ratings)
Gilles Dufour Mon, 06/08/2009 - 01:06
Did you define proximity constraints ?
CSCsi08784 GSS should send SERVFAIL rcode if proximity constraints are not met
Or does it match the same rule from the dns server and from a client directly ?
