Locked: line cons 0, login local
Jun 5th, 2009
Hi, on a 3750, if I do:
line cons 0
login local
Then I did not set any user name.
When I attempt to logon, it prompts for a username though.
What would be the username and password I should use in this case? Thanks.
Jon Marshall Sat, 06/06/2009 - 02:07
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Marlon
You will need to create a username/password as there is no default as far as i know.
Jon
davy.timmermans Sat, 06/06/2009 - 02:35
  • Silver, 250 points or more
If you're not able to login via telnet password recovery is your only option.
Press on the mode button for 10seconds. The switch will reboot and rename startup (config.text.renamed)
When you're in privileged mode, you can do a copy config.text.rename run.
Now you can set a username and password.
The other way to do password recovery is pushing on the mode button while booting
>rommon mode
rommon1>flash_init
rommon2>rename flash:config.text flash:config.renamed
reset
en
copy
copy config.renamed run
username xxxx secret yyyy
